Scan from pc at 3640 mfp?
  • L0rdC
    • Feb 2021
    • 82
    Hello, a client has asked me this morning if he can scan from the pc on this machine, as he did from his old brother with CC4, is it possible on this machine?
  • kuby
    • Oct 2007
    • 1400
    Re: Scan from pc at 3640 mfp?
    I think it has scanning software you need to load. Not familiar with that model.
    • patrickjlc
      • Feb 2015
      • 225
      If you mean scan to pc from the 3640, yes. Both have to be connected to the network, thru ethernet.
      AFAIK you can't scan thru the USB
      Sent from my motorola one 5G UW using Tapatalk
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1884
        You need special fimware, unless they are running an old version of windows. Those machines didn't support SMB V2 or V3, which is needed to scan to Windows 10.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • PrintWhisperer
          • Feb 2018
          • 471
          Possible, but mainly as a Pull scan operation, Send protocols on this system are too old except for FTP.
          Scan FROM PC (Pull) -> TWAIN driver (same as FS-2626, available on product CD), WIA drivers might be built into Windows (USB or Network) Try plug and play discovery in Printers and Scanners.
          Scan TO PC (Push) -> FTP is best bet, SMB 1.0 only will not support newer systems and no TLS for email (Network only)
          That machine is what we call...'rare'
          "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
          • KyoServiceManager
            • Oct 2017
            • 30
            I would suggest using the firmware for security purposes, however, SMB V1 scanning is possible on Windows 10 by accessing the Windows Features, and turning on "SMB 1.0/CIFS File Sharing Support." All 3 boxes need to be checked and the PC will need to be rebooted after making the change. Just wanted to throw this out in case anyone needs it in the event limited options or specific customers.
            "If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?" -Einstein
