Kyocera M5526 with black smearing in vertical direction
  • i-have-fax-problems
    • Mar 2020
    • 106
    Hello,
    we have a M5526 Kyo which has black 1 inch wide smearing, spots in vertical direction but not on all pages.
    I did the drum refreshment function then some pages where ok than stripes again. Do I have to replace the drum then and
    the DV Box or what else can I do. But I guess changing drum does not pay.
  • allstar59
    • Oct 2012
    • 64
    Sounds the transfer belt cleaning unit. We usually just clean it out and check the passage in the drum unit....It's too bad those cleaning units aren't available separately....
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 700
      The drums on this series are awful. If it magically isn't the black drum, it's the transfer. Shame it's not under warranty anymore, Kyocera always accepts those if you do the proper paperwork.
      • Rpizzle
        • Mar 2014
        • 47
        no kidding of course kyo doesn't offer that part. They're out there though.
        • copyTcat
          Senior Technician
          • Apr 2015
          • 58
          Try to replace first the drum charge roller
          • Black Cloud
            • 163
            I have received three Transfer Belt Cleaning Units through Aliexpress. I have not used any yet so I don't know how good they are. Here is the link -> https://www.aliexpress.com/item/1005007341988783.html
            Net+ PDI+ @Remote
            • Ferrell Max
              • Dec 2024
              • 2
              The same, I am unaware of their quality, as I have not yet employed any.
              Originally posted by Black Cloud
              I have received three Transfer Belt Cleaning Units through Aliexpress. I have not used any yet so I don't know how good they are. Here is the link -> https://www.aliexpress.combitlife online/item/1005007341988783.html
              • OlliK1969
                • Nov 2016
                • 311
                Hello, I had 3 of the units delivered and installed them last year and have not received any negative feedback from customers so far. However, it must be said that customers only use these devices in their home office and create around 5-8,000 pages a year. But as I said, no negative feedback from customers and the devices are currently in use.
