5053ci intermittent horizontal blanking
  • yakyitz
    • 245
    [CQ] 5053ci intermittent horizontal blanking
    This machine is just out of warranty and I don’t want to just throw parts at it. It goes from one minute to the next full solid to blanking. I don’t believe it’s a charge issue as it doesn’t go solid to the edge it blanks. It’s got to be either transfer belt which was recently replaced as it somehow got all chewed up,or the HVPWB. I’ve attached full sample set of issue and the maintenance, event log and a good sample set.
    Any ideas? Anyone?
    HCScq.pdf HCSmntrprtGCQ.pdf
    (reposted from printer forum)
  • kyotechnz
    • Mar 2019
    • 145
    First impression I would look at transfer (roller and belt) as it appears to be happening across all colours.
    Also it is easier to swap these parts.
    Haven't seen this before on a this series, but the Transfer Belt and Roller is where I would start.
    Also if I remember right there is a Bulletin about the Transfer Belt connector not making proper connection, you may want to look there.
    • toddanderson
      • Dec 2005
      • 236
      Replace the 2nd transfer high voltage pwb
      • yakyitz
        • 245
        in the manual there are 3. You obviously don’t mean the one mounted on the transfer belt. Of the other two, which one are you referring to.
        Transfer connect PWB Relay circuit for feed image PWB and transfer PWB.
        Transfer high-voltage PWB Generating the transfer bias, separation bias and transfer cleaning bias.
        Transfer PWB Storing individual information on EEPROM. Relay board the belt cleaning motor/
        belt thermistor and feed image PWB.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1885
          302ND94640 I believe is the one he's talking about. Does your repetitive defects guide point to the secondary transfer roller diameter ?
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • yakyitz
            • 245
            take a look at the image I posted it’s not consistent
            • tmaged
              • Oct 2008
              • 1885
              Yeah you're right. Stopping it with the image on the belt should tell you if it's Primary or secondary.
              Hope that helps !
              -Tony
              www.dtios.com
              • JR2ALTA
                • Feb 2010
                • 2033
                I don't see transfer. I see developer bias or MC voltage issue. Both are controlled by the Main HV pwb
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  Any update on this?
                  • yakyitz
                    • 245
                    I just today replaced the Transfer high-voltage PWB. But we’ll have to wait and see if it actually resolves the issue as it’s intermittent. It was working fine today when I got there, so time will tell. If I get a callback I’ll post an update.
