TA 520i Image issues
  • Brandon
    • Jun 2019
    • 72
    Good morning
    I have a TA520i that is smudging / smearing the text/image in certain places , i have tried another drum unit and developer unit but has made no difference see attached sample
  • Samanator
    • Sep 2017
    • 579
    Re: TA 520i Image issues
    Is this made off the glass or through the ADF?
    • Brandon
      • Jun 2019
      • 72
      print from PC
      • darry1322
        • Oct 2010
        • 817
        Originally posted by Brandon
        Good morning
        Broken holder/spring on your transfer roller.
        • Brandon
          • Jun 2019
          • 72
          thank you are you referring to the transfer roller on the door by the fuser section that opens to remove paper jams ?
          • darry1322
            • Oct 2010
            • 817
            That's the one.
            • Samanator
              • Sep 2017
              • 579
              This might be a long shot but I have seen it before.
              Is the left side cover latching when closed? Many times when someone closes that left side cover, they may push it closed on the front side not in the middle. The cover may look closed but its not latched in the back.
              Just a thought.
                • 23008
                +1 =^..^=
                • Brandon
                  • Jun 2019
                  • 72
                  +1 =^..^=
                    • 23008
                    Ok, I can translate:
                    I agree with darry1322. You should check to see if the transfer springs are still in place. =^..^=
                    • kjg
                      • Mar 2009
                      • 111
                      Try changing both the transfer roller assembly and the drum input guide that comes in the maintenance kit. Both have caused me that grief in the past on multiple 420's and 520's.
                      • Brandon
                        • Jun 2019
                        • 72
                        Drum input guide ?
                        • Brandon
                          • Jun 2019
                          • 72
                          Drum input guide ? do you maybe have a photo to send me ?
                          thank you
                          • kjg
                            • Mar 2009
                            • 111
                            Parts Guide Transfer, 302GR94481. In parts manual page 11 Item A03. It comes in the maintenance kit. It sits just below the drum between the drum and the transfer roller and is held in with a single screw. You will need to remove the drum to replace it.
                            It usually has a yellow sticker on it warning users not to touch the drum surface.
                            • copydocinc
                              • Mar 2015
                              • 263
                              The spacing of these smudges looks like possible fuser unit.
