Taskalpha 6053ci toner doors
  • ChrisG
    • Oct 2013
    • 188
    Have several of these machines in the field now but first time seeing this. The yellow toner refuses to open even when the machine is saying it's out of yellow toner. We manually released it and added the toner which made the machine happy. The other odd circumstance is all 3 of the other toner doors open whenever you open the toner access door even though none are showing that they need changed? I didn't see anything on the bulletins from KDA or have any luck on the various Google searches.
    If anyone has run into this before we start chasing boards, sensors, etc etc your help would be appreciated.
    Chris
    TJL Copy
    • 920
    Re: Taskalpha 6053ci toner doors
    SIM. 159 gives you options on when the toner doors will open
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1901
      Besides the sim, check that the release lever is back in the lock position and not stuck in the open position. I've seen that happen before.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
        • 23010
        Another consideration: If you get an error message, especially an enduser resettable one like C1020, the toner doors all pop open during an error condition. I've had to tell customers that you do not necessarily have to change the toner cartridge if it's not asking for it, but the toner door pops open. =^..^=
