Ecosys M6235cidn jam 4211
  • safirod1
    • Jan 2020
    • 5
    [Jamming] Ecosys M6235cidn jam 4211
    Hoping everyone that reads this case had a nice and safe Thanksgiving.
    I'm working on this MFP printer that for some reason and based on the event log it jams 2 times on the first print or copy, obviously it shows the jams most likely in the morning when the customer turns on the printer, but after that it works perfectly, it currently has the latest firmware, the MR is at 5K prints, feed rollers for tray and a new fuser were replaced just to make sure rollers and fuser weren't the cause, loaded Kelly paper that we normally use to set up the machines, brought machine in shop and tested around noon and same couple jams, after that machine works perfectly, single and double sided, cassette and MPT. I turned off printer let it cool down for couple hours and tested again, same jam 4211.
    Any suggestions are greatly appreciated.
  • Ropariva
    • 693
    I had this several months ago and it was very frustrating. Turned out the flag on the fuser exit was slow to return when “cold” but freed up and resumed normal operation as it warmed up. A bulletin has just been released re this. Replace the fuser or remedy the slow flag movement.
    • safirod1
      • Jan 2020
      • 5
      Thanks Ropariva, you are very right I just found a bulletin that affects different models because of the fuser exit flag. just in case I attached the bulletin in case you need to cross reference the serial number or new part number.
