Kyocera FS-4300DN Firmware - Errorcode F25E - MacOS 12
  • Mac_Printer
    • Oct 2021
    • 10
    #16
    Re: Kyocera FS-4300DN Firmware - Errorcode F25E - MacOS 12
    First problem solved, we just added the printer manually over the IP with the LPR porting. Printer queue left empty. Now it works and we can print from our macOS Monterey Mac's
    Thanks to all helpers!
    A small problem has been added, however, when we print a pdf with the preview, all three cassettes can be displayed during the selection and are available.
    As soon as we open a document using Adobe PDF Reader and want to print it, it is no longer possible to select a cassette, only the first cassette is displayed.
    Maybe someone will have some more advice.
    • PrintWhisperer
      • Feb 2018
      • 465
      #17
      How to on Print Panel:
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • Mac_Printer
        • Oct 2021
        • 10
        #18
        Originally posted by PrintWhisperer
        I had also set it in the Print Panel, but it still only shows me one cartridge in the print preview of a pdf document in the acrobat reader. With another mac with the same adobe version and macOS this works and all cartridges are displayed.
        • PrintWhisperer
          • Feb 2018
          • 465
          #19
          Check to see that both are using the same PDL, recommended would be KDPL. 'PDL Switch Tool' chapter 2 of above manual.
          Device options flow from PPD indentified for driver, and may differ by PDL. Ensure drivers are identical as well.
          • Mac_Printer
            • Oct 2021
            • 10
            #20
            Thank you very much, changing the PDL setting helped and now it's working again
            • PrintWhisperer
              • Feb 2018
              • 465
              #21
              Good job, way to stick with it!
