Ecosys P3055dn Error 6120:0104812
  • Ziggy
    • Feb 2018
    • 693
    I cant find in manual how to reset this fuser error. I work mostly on Konica Minolta and would greatly appreciate if anyone could tell me how to get into service mode while this machine is in an error state and reset this code. Or will simply replacing the fuser resolve this error?
  • ronny2502
    • Mar 2020
    • 78
    Hello,
    afaik these little machines don't have a TroubleReset (U906) or anything like that.
    I'd start by replacing the fuser unit.
    Be careful when installing a new unit! -> Release the pressure first: Open the back cover for a few seconds when switching on.
    Good luck!
    Ro
    • Dark Helmet
      • May 2009
      • 835
      To expand on this, when you remove the fuser, the cam usually has the fuser pressure turned on. It is very difficult to install the new fuser in this position. With the fuser out of the machine and the rear door open, power the machine on, watch the cam rotate to the down position and then unplug the machine. Now you can install the fuser easily.
