Kyocera TaskAlfa 5550ci
  • Chlgmchjiru
    • Jun 2021
    • 35
    [Misc] Kyocera TaskAlfa 5550ci
    I have kyocera taskalfa 5550ci machine to be maintain. Evry thing is ok. But the back side on header is color mixed toner, but the printe side is clear image. When i print (no copy) only black and white there is no problem. Plc anybody who experianced on it help me how to solve it.
  • rapo_tech
    • Feb 2019
    • 114
    Re: Kyocera TaskAlfa 5550ci
    Secondary transfer roller is depositing toner on back side of paper.
    Common cause is using non-OEM toners.
    • Chlgmchjiru
      • Jun 2021
      • 35
      Oh! this is the most problem in our county. Can i use minolta bizhub toners for kyocera?
      • rapo_tech
        • Feb 2019
        • 114
        -e- and keep in mind that, there is plenty of toner in developers. It takes time when all the shi%ty toner gets used.
        Quick fix is maint kit A and B and OEM toners
          • 23006
          um, ... no ... you can't use Konica Minolta toners in Kyoceras. Not if you care what the image quality looks like.
          If you have an image quality issue, it would be a good idea to attach a quality sample of these images:
          • Chlgmchjiru
            • Jun 2021
            • 35
            There is no error code or jam message on this machine the only problem is top back side toner gohost. I have service manual and look solution for this trouble. It shows to clear groove on Paper transfer roller. I did it. Further more i have cleared transfer belt cleaner, all chargers, and all drum cleaners, but no change.
              • 16374
              Slow down and read what the other members are telling you.
              Post an image of the problem you're having. And stop clearing the counters.
              • avio2
                • Jul 2010
                • 150
                this problem is in all multicopy or only in fisrt copy?
                • Chlgmchjiru
                  • Jun 2021
                  • 35
                  Yes it is on all multiple sheets. Further more when i looks on there is toner gohost on belt, that means it is not cleared. The amount of Color toner on secondery transfer roller increas as number of page increase for multiple copies.
                  • dalewb74
                    • Feb 2018
                    • 1143
                    just a suggestion. but you should call a kyocera tech. if you don't know that you can't use another brands product in a kyocera. if you do certain things to a copier incorrectly you can pretty much brick the machine. then you won't be able to do anything. and since you were asking about the toners, don't use generic....
                      • 23006
                      Chlgmchjiru:
                      Just out of curiosity, how did you get 102 years of experience, when you're only 42 years old?
                      Were copiers even invented in 1919? Some of the earliest facsimile, perhaps.
                      • Chlgmchjiru
                        • Jun 2021
                        • 35
                        Dear blackcat u make me funy! It is about 1919 &2020. I'm juniore fresh technician. Tank for all ur very intersted and important posts.
