bad print problem MA 4500ifx
  • Exodia-P4
    • Jan 2023
    • 135
    Hello,
    I have a little problem on a MA 4500ifx.
    The left side of the print is not or bad printed...
    I clean the laser glass, change the PCU and change the dev but I already have the problem...
    I think I must clean the laser unit completly
    Thanks for your help
    20250115175827937.pdf
  • Larhal
    • 609
    What was the original problem. Is the machine extremely dirty? do you us Original Utax toners? There may be a spill on the one side or toner has gotten inside the laser.
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • kjg
      • Mar 2009
      • 112
      Pull the charge roller unit out completely and make a print. you should get solid black. if you still have the same issue then its not in the LSU. Try a panic stop and Check drum to see if solid black image is staying on drum. could possibly be transfer pressure issue.
      • Dark Helmet
        • May 2009
        • 858
        Check that the transfer roller is seated properly under the drum.
        • Exodia-P4
          • Jan 2023
          • 135
          Hello everybody and thank you for your help
          The printer in not dirty, It's OEM toners. I check the transfert roller and it looks OK...
          I will bring back the copier to my warehouse in order to completly clean the laser.
          Good bye
          • Exodia-P4
            • Jan 2023
            • 135
            Hello, I find the problem. the laser is very dirty. I clean It and it's OK. Thank you for your help
            • Lunatech
              • Oct 2012
              • 213
              Good job! Thanks for letting us know.
