306ci/307ci/308ci Color trouble
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1868
    I recently spent time working on a 307ci that had the 3 colors washed out, but black was fine. The U410 shows from a good 308ci & the problem 307ci. After trying U021, HV PWB & Primary belt, I ended up finding that the transfer belt release motor housing was cracked. We had one in stock as I've replaced a couple in the past that generated errors when the shaft in it broke. This machine didn't have an error code. I pulled apart 4 different machines in our warehouse & all 4 had that housing cracked. I know one of them had light yellow prints that we never could remedy and ended up replacing with a 308ci.
    I'd say if you're having any color issues on these series of machines, that would be a good place to start. I doubt at this stage in the lineup that the part will get updated, and 40 & 50 uses the same part.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  • Dark Helmet
    • May 2009
    • 835
    Good catch!
    • yakyitz
      • 243
      I have the same problem with a 358ci but apparently it doesn’t have a transfer belt release motor.
      • tmaged
        • Oct 2008
        • 1868
        It shows up on the 358ci parts guide 302R431810. It's on the front frame under the black plastic that goes around the cavity of the machine.
        Hope that helps !
        -Tony
        www.dtios.com
        • yakyitz
          • 243
          Thanks tmaged, oddly enough it’s not in the SM listed in the design/electrical/motors. But you’re correct it’s in the Parts manual. I’m going to check it out and hopefully will resolve the issue.
