The print is light on both edges when i replace drum kyocera 5002i
  • dacam20590
    • May 2019
    • 30
    The print is light on both edges when i replace drum kyocera 5002i.before that drum was striped
    this month i changed 5 drums for 5 different machines and got this problem. Only when I refresh the drum 5 times did the print go black again. But the next day the problem persisted and was light4581e2f12162e93cb073.jpg9d55ac1b6f88a7d6fe99.jpg
    • 23009
    Re: The print is light on both edges when i replace drum kyocera 5002i
    It looks like condensation on the drum. Is this a particularly moist season? =^..^=
    • Ropariva
      • 680
      As these drum age they become more prone to humidity and moisture.
      You will need to fir a dehumidifier and tip urn on U327 mode 2, on all the time.
      • dacam20590
        • May 2019
        • 30
        yes this is particularly moist season.I'm i read a document about u100 code i will try today
          • 23009
          I would make sure that the cassette heaters are installed and ON, an that U148 is set to 1=short.
          Adjustments to primary charge will not help. =^..^=
          • rapo_tech
            • Feb 2019
            • 114
            Did you push the developer shaft lock?
            Common problem is the shaft lock is defective and wont stay in locked position.
            So the developer roller and drum roll cap will be too big and the result is something similar you posted.
            Easy fix is glueing something on developer lock shaft or inside the inner cover.
            If warranty machine, they should replace developer.
            -e- Are your samples printed SEF? If yes then I agree with the moisture problem.
            • ntbann
              • Jan 2012
              • 628
              The easy fix for the DV lock is to drive a screw in between the lock button and DV frame.
              • dacam20590
                • May 2019
                • 30
                yes i see U148 set 1
                For 5 days now, every morning I have to refresh the drum 4-5 times
                I noticed in the morning there was a light error
                I'm really confused
