regulation firmware for ecosys m6526cdn
  • bekop
    • Mar 2024
    • 3
    HI Guys!
    Has anyone perhaps heard of a control firmware for Ecosys m6526 similar to the firmware for fs-c2126.(trouble registering colors)
  • Ropariva
    • 671
    Yes, but unnecessary. Just repeat manual registration several times and it will come back to the middle. Have done this many times You just have to make sure you are going the right direction. Enter 9 on each colour the first time nd print chart. See that it’s going the right way and if it is, do it over and over till it’s close enough to do auto registration.
    • bekop
      • Mar 2024
      • 3
      I know this procedure and have used it many times. However, the colors diverge after not very long time. I used the adjustment firmware in the fs-c2126 and it seems that the copier, as the transfer belt ages, learns new levels on the color registration sensors and stores them in memory. Unfortunately, the firmware from fs2126 cannot be used in m6526 .
      • KYO_OEM
        • Aug 2011
        • 712
        try this one like old Gemini
        • KYO_OEM
          • Aug 2011
          • 712
          here the bulletin
          I think new belt needed, because the belt is getting too long.
          You can see this because the two strips on the underside at the front and back are no longer glued together exactly.
          A gap can be seen there
          old problem of the Gemini series
          • bekop
            • Mar 2024
            • 3
            Thank you for the files. The belt is in very good condition. It has made only 55000 prints. Firmware solved the problem with simulation 34. Everything is back in place. Once again, thank you very much
