Kyocera ecosys m6526cdn - dont sense the paper presence in tray 1
  • luca72
    • Oct 2017
    • 1791
    hello everyone, I usually follow ricoh, but I also know some kyocera so-so, I'll start by saying I have the SM.
    we picked up an ecosys M6526 from a customer, the boss wanted to give gift to a sports association that doesn't have big demands, and asked me to take a look at it.
    the problem is that the machine doesn't sense the paper in drawer 1, the by pass works fine.
    I tried to disassemble and check the mechanism of the paper presence detection feelers, and mechanically everything is ok, I cleaned the sensors of the small board, the drawer lift motor is ok too, but it always says that the paper is missing.
    I wanted to try to update the firmware, but both on the site and on my-kyocera there are only drivers for this model.
    has this problem happened to anyone? how did you solve it?
    thanks.
    "I'll be back"
    • 23010
    Three common failures are:
    1) paper size detection switches
    2) paper empty sensor flag
    3) paper lift gear and or housing
    Exactly what is being displayed?
    • luca72
      • Oct 2017
      • 1791
      hi, the m6526 display the tray empty and say "add paper in tray 1".... i perfom also factory reset from service menu, but nothing its happened
      "I'll be back"
      • luca72
        • Oct 2017
        • 1791
        hey!...i found out that set like this, works, and it sees the paper in the drawer!..but the customer would get a bad stiff neck....LOL...LOL..
        there must be some problem in the activation of some sensor.
        "I'll be back"
          • 23010
          Did you attach an image? All I see is a rectangular black box.
          • luca72
            • Oct 2017
            • 1791
            Strange, I see the photo from PC and from smartphone, try with another device, maybe Windows Need a reboot
            "I'll be back"
            • luca72
              • Oct 2017
              • 1791
              I disassembled, checked and rechecked the paper presence sensor lever under the machine, and I'm sure everything is ok,
              but I don't understand why if I tilt the machine on one side, the drawer magically appears full, and it prints fine, does anyone have any ideas?
              "I'll be back"
              • luca72
                • Oct 2017
                • 1791
                QUOTE=blackcat4866;n1601155]Did you attach an image? All I see is a rectangular black box.[/QUOTE]
                [SOLVED] hey guy, its solved, it was a bad solder on the paper sensor board, I gave it a refresh with the soldering iron and new tin, and now everything works great.
                thanks to blackcat for the collaboration.
                "I'll be back"
                  • 23010
                  Good catch! You don't see a lot of bad solder joints these days. Not like the old days when I could fix a lot of the power supplies just by re-soldering the connector pins. (I can see these images.)
                  I'm betting that when you tipped then machine it twisted the circuit board slightly, making better electrical contact. Congratulations!
