Kyocera Ecosys P2040dn, issue: "garbage"printing
  • brunot
    • May 2012
    • 148
    [Misc] Kyocera Ecosys P2040dn, issue: "garbage"printing
    Hello everyone,
    I need your help, to solve this issue (see attached "garbage" printing)
    The printer is connected to a laptop or PC via USB cable (see attached Windows version).
    Each time I switched the printer off and restarted the printer, the same issue occurred.
    Printer power on, I unplugged, then plugged the USB cable to PC or laptop: same issue.
    Installed the latest driver and the latest firmware: same issue.
    Sometimes the printer keeps printing over and over all day until it runs out of paper!
    REMARKS:
    When I removed the USB cable from the PC or Laptop, I switched off the printer. When I restarted the printer, there was no garbage printing, but after a few minutes, the same issue occurred.
    All printers using network cable are working properly.
    Thanking you in advance
  • kyotechnz
    • Mar 2019
    • 145
    Try turning off WSD Print on the printer.
    Delete the printer off the PC.
    Install KX driver instead.
    See what happens.
    • copier tech
      • 8172
      You have a computer on the network with the wrong driver. You can confirm this by restarting the device with the LAN & USB cables unplugged.
      • brunot
        • May 2012
        • 148
        See what happens.
        Installed the latest driver KX and the latest firmware: same issue
        • davel
          • Oct 2011
          • 1107
          The driver for USB printing is wrong one.
          • brunot
            • May 2012
            • 148
            Its the same driver KX just need to change the port to USB or IP address.
            • PrintWhisperer
              • Feb 2018
              • 473
              This has been reported as being caused by Windows updates:
              Fix
              Booted from a Windows install USB, Choose Troubleshooting and uninstalled the last Quality Update.
              This removed KB:5050081 and after rebooting the issue went away.
              The data is typical monitor traffic from Windows to its IPP ports set up via WSD so certainly turning those things off at the device (as suggested) will prevent you from getting the gibberish at your printer.
              "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
              • brunot
                • May 2012
                • 148
                Noted with thanks.
                • PrintWhisperer
                  • Feb 2018
                  • 473
                  The monitor messages which are printing have been found to be related to a Widows feature used on USB ports. The feature can be turned off using the attached procedure. Windows-11-10-USB- Print-Issue-03-25-2.pdf
                  • brunot
                    • May 2012
                    • 148
                    Originally posted by PrintWhisperer
                    The monitor messages which are printing have been found to be related to a Widows feature used on USB ports. The feature can be turned off using the attached procedure. [ATTACH]n1606945[/ATTACH]
                    Well noted. I will try these settings, and I will give you feedback.
                    Thank you.
