Kyocera 300ci vertical lines on copies
  • stern.detmold.32756
    • Feb 2018
    • 25
    Our Taskalfa 300ci misses color in vertical lines when scanning. The problem occurs both through the feeder and the flatbed.
    We have cleaned the glass thoroughly and prints are just fine.
    Thanks in advance
    • 23006
    Re: Kyocera 300ci vertical lines on copies
    Are you going to ignore the previous responses to your question in the previous thread(s) that you started?
    Does this remind you?:
    https://www.copytechnet.com/forums/k...t=#post1966338
      • Feb 2018
      • 25
      Hi,
      no I'm not ignoring the responses, that problem seems to be linked to the settings of the copier, as it was fixed by the tip of changing the settings.
      The other printer only had problems with the dotted lines on the font list, this printer has problems with everything.
