km4050
  • PANG
    • 104
    km4050
    Hi ! ALL i have a some problem here which is when send print from pc ,copier cant print the file out. Check copier status shown ' paused' on this file and cancel it but its failed deleted, only off on machine, the file only gone.Those incoming file will print out in sequent. My supervisor ask to reformat HDD by sim mode i dont think is related .as i think that when send print from pc to copier the file will send thro printer kit and print out ,i hope i m right .Hope your explanation can help me clear my dout. THANKYOU
  • cboucher
    • Jul 2025
    Your supervisor could have a point. I wouldn't hurt to give it a try. You might also want to try reflashing the firmware. Is this a shared printer? If so, you might want to check and make sure there isn't a stuck job on someone's PC that needs to be deleted. Good luck...
    • PANG
      • 104
      YES , its shared copier about 30 over user.
      • Cirrus
        • May 2008
        • 43
        Definitely reflash the firmware. I had this problem many times when this machine came out until I got to a certain level of firmware.
        • vikingmita
          • Nov 2008
          • 163
          oh yes. new firmware AND format hd. unless we're talking lots of stuff in adress book (will be erased), go ahead
          • PANG
            • 104
            May i know what is the latest firmware can sovle this problem ? I like to share with u all how i do it ,sim 917 to export to thumbdrive and format hdd,off on machine start to import back to machine by sim917 .thats it. u all think is it all right by this way? THANKYOU.
              • 23008
              The latest version in the US is version 2.20C1
              • kyoceradude
                The Great Gazoo
                • Aug 2006
                • 442
                Guess what? 2.20D just came out....................
                My mission here on Earth is to help all you Dum-Dums!
                  • 23008
                  Just my luck. This is like those converstions you have: "You know, we haven't had a call lately from Customer X." ... and then the dispatcher hands you the call. =^..^=
                  • PANG
                    • 104
                    Actually i like to know about this version
                    what problem its can solve or if u dont mind , can u send servicing bullliten here so that we can shared information.Thankyou.
