Kyocera 2552ci or 2553ci fuser drive gear needed
  • gideon
    • 283
    I have the manual.
    There is no part number for the fuser unit drive gear (the gear on the unit itself) any idea what the number?
    The printer has a load grinding noise, when I remove the fuser unit gear no noise, the gear on the unit rotate freely no noise.
    I'm going to replace the fuser drive unit, I'll like to replace the fuser unit gear at the same time.
    If you experience this noise from the fuser and have another suggestion I'll like to here it.
  • Ropariva
    • 676
    Nothing is available separately as the drive is a complete unit and so is the fuser.
    • Lunatech
      • Oct 2012
      • 208
      Nothing except these: for the drive unit, not the fuser itself.
      • kyotechnz
        • Mar 2019
        • 145
        Check Service Bulletin 2XD-0044(M029).
        You should be able to order the Motor (302ND9405) and Gear (302ND3149). These are know to cause issues.
        • Lunatech
          • Oct 2012
          • 208
          Yes. Those parts have been problematic, causing c6610. Though the part numbers I have are: motor (302ND94050) Gear (302ND31490). The same only with another zero at the end.
