TA3253ci lockup during send/copy fyi
  • sparkycivic
    • Apr 2017
    • 348
    Well, a new year, another new headscratcher.
    Symptom was device locking up during scans to smb/USB, no email configured, sometimes also delay or lockup during copy. It started intermittently during large jobs, then got progressively worse to the point that any job over 1 page might lockup the device.
    They hadn't mentioned the pausing during feeding of originals, until late in my troubleshooting process, so I was first going for network delays.
    Turns out that the HDD storage device was the culprit! I arrived, and immediately recognized the hesitation during feeding, and put in an identical replacement HDD(WD 320GB WD3200LUCT). No more scanning lockup or copy delay/lockups.
    I was expecting that an error C0640 should be displayed, but unfortunately this model of device is unable to detect/warn of HDD failure which would have been expected behavior from the service manual. Wasted a LOT of my time and customer lost productivity chasing this one down!
    The SMART statistics pulled from the HDD don't seem to indicate past or pending problems... Acronis Drive Monitor tells me the drive has 270 days of power on time and no data for pending, uncorrectable, UDMA, reallocated sectors, recalibration retries, read error rate, seek error rate, spin retries or write error counters.
    I won't be able to tourture test this drive until after the warranty claim goes through...
  • Ropariva
    • 674
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1885
      Re: TA3253ci lockup during send/copy fyi
      I thought the SSD was used for copying/scanning/fax memory to make it faster and the HDD was used for document storage etc ?
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • sparkycivic
        • Apr 2017
        • 348
        The stated purpose of the SSD is to speed up the power on boot process, so the firmware, running software, dictionary, address book and other stuff is stored there. That's why it's only 8GB.
