Kyocera - Toner level
  • Keppler
    • May 2025
    • 15
    Hi all,
    Does anyone know which MIB shows the printer's toner level?
  • ThisPete
    Snr/troubleshoot/network
    • Jun 2014
    • 248
    A clue on which device would help, does the 'status page' printout not show this?
    • Keppler
      • May 2025
      • 15
      Yes, the status page shows this information.
      I have 10 printers and would like to view the toner levels of all printers simultaneously.
      Kyocera provides Net Viewer software, but only for Microsoft Windows.
      That's why I would like to get the information from all printers simultaneously, via SNMP.
      • ATM
        • Apr 2025
        • 50
        Do you need that info for specific monitoring software?
        • Keppler
          • May 2025
          • 15
          Hi,
          Thank you for your feedback.
          I found a website that tells you the OIDs for toner levels.
          There are two OIDs:
          Maximum toner level (1.3.6.1.2.1.43.11.1.1.8.1.1)
          Current toner level (1.3.6.1.2.1.43.11.1.1.9.1.1)
          Using snmpget, I took the values ​​and converted them to percentages.
          snmpget -v2c -c public 10.10.31.30 1.3.6.1.2.1.43.11.1.1.8.1.1 (return SNMPv2-SMI::mib-2.43.11.1.1.8.1.1 = INTEGER: 21000)
          snmpget -v2c -c public 10.10.31.30 1.3.6.1.2.1.43.11.1.1.9.1.1 (return SNMPv2-SMI::mib-2.43.11.1.1.9.1.1 = INTEGER: 19740)
          Toner level is: 19740 / 21000 * 100 = 94%
          Then I created the table below.
          Thank you very much
