PA6000x toner chunks
  • AJL45
    • May 2020
    • 17
    I have a PA6000x that keeps leaving toner chunks on prints. The fuser roller gets coated in toner which then starts leaving toner chunks. I change the fuser, and it works fine until the toner starts building up on the fuser again. I tried changing the drum/developer/fuser this last time, but after 2 months, the issue is back. OEM toner is being used. Any one have any ideas?
    Thanks!
  • Kyodogs
    • Apr 2024
    • 12
    This is the same issue that was never taken care of in their previous versions
    Adjusting heat and timer settings does nothing to help this.
    You replace the fuser unit, which is good until the pressure roller builds up toner again.
    *Kyocera tech support is clueless.
    Plan on cleaning that roller with alcohol a few times a year for free if it is on a per-call basis.
    "If you sell lower-end Kyocera and put them under contract, you will lose your shirt, if you sell lower-end Kyocera outright, you will lose a customer"
    • Dark Helmet
      • May 2009
      • 865
      Thanks!
      Any chance they are running labels or thicker paper with out setting the media type properly? Might need to bump the heat up.
        • 23010
        That was my thought. Are they running heavy media on plain paper settings? Is it genuine toner? Both of these can produce the symptoms that you are seeing.
        • nathicana
          • Aug 2008
          • 335
          Set the paper type to bond on the printer.
          Machine speed and duplexing will be unaffected.
          By default the driver media type is unspecified so the printing works the same for the customer.
          • AJL45
            • May 2020
            • 17
            Genuine toner, and just plain paper. I will try setting the the paper type to bond! Thanks!
            • ntbann
              • Jan 2012
              • 631
              I have seen this twice now. I warrantied both and Kyo wanted them both back.
