So I have a Taskalfa 3051ci with just under 100k total prints on it and it has issues with a repeating black "blob" on it. I measured it out and compared against the defect gauge and turns out it's the PCR. I confirmed by swapping it with the yellow PCR so time to change it out. There was a spare PCR in the drawer so I took it out, it looked fine, was clearly unused so I replaced the yellow PCR.
First color test print, another blob, which got slightly larger with each page until it settled at it's final size. See the "PCR-Change" attachment. When I removed the PCR, it clearly has a gap/pit or whatever you want to call it - see the "PCR-Gap" attachment.
Is this just caused by crappy Chinese PCR's, or is there something else going on here? I don't know where the spare PCR came from so I can't say for sure if it is OEM or not. I also can't see anything in the developer or drum unit that would cause any mechanical damage but I'm going take them out and do a full clean just to make sure.
Most of what I've been able to find here refers to "bumps" and potential arcing to the drum with these PCR's, but not so much about the pits. I may cut open the old PCR and see if there is anything under the surface that might allude to the source. I do need to run U930/U464/U410 but I'll wait for proper replacements.
Anyone have any insight on this?
