Ecosys 2540dw blank pages
  • Paulm
    • 69
    Hi all, I have a Ecosys 2540dw that prints blank. Have swapped DV and drum. Any other ideas rather than PWBs. Has anyont fixed tis? Most Likely issue?
  • ATM
    • Apr 2025
    • 42
    Check if the drum cover is damaged. Sometimes the hinge is damaged and causes the cover not to open. It is best to remove the cover from the drum and check without it.
    EDIT: I see, you checked drum unit. Looks like power issue.
      • 898
      Make sure the guide for the drum is properly seated .
      • kuby
        • Oct 2007
        • 1408
        Are the internal prints blank also?
        • ihatefinishers13
          Senior MFP Technician
          • Feb 2020
          • 709
          Did you try turning off the machine, reseating the drum/DV units? Very common problem if you don't turn the machine off.
          • lees
            • Apr 2011
            • 95
            We have seen blank pages on copy and print several times on this series of printers and MFP's. Every time so far, it has been a main board. Hope this helps.
