Kyocera Ecosys PA2100cx toner issues
  • valonqar
    • May 2025
    • 8
    I replaced the flex cables of the drum unit and the developer unit of my Kyocera Ecosys PA2100cx and now I'm finally printing (previously was printing in blank), but there's still some issues about the colors. Once printed a page it starts showing the message "adding toner" and then ask to replace the toner, even tho it is completely full. It happens with genuine toners and compatible toners. Does anyone know how to solve this problem?
    Do you guys think it is a problem in the waste toner sensor? I don't know which part of that printer it is located this sensor.
  • ntbann
    • Jan 2012
    • 628
    Sounds like the toner supply tubes going through the transfer belt are plugged not allowing the dv units to tone up. Is it all the toners or just a certain color?
    • valonqar
      • May 2025
      • 8
      All of them, but it happens mostly with C, M and Y. My last print test it is not printing the color cyan, but in the screen keeps saying the toner is low, but it is completely full.
      • Larhal
        • 580
        Remove the transfer belt and vac out the toner supply tubes. This will eliminate one potential problem. And by all means do not use compatible toner ......
        Larhal
        If all else fails read the Service Manual!
        If that fails, meet me at the pub and we will discuss it.
        • valonqar
          • May 2025
          • 8
          Thank you ntbann and Larhal ! It seems to resolve one of the problems, it is stopping showing the message "adding toner" all the time and it's printing all the colors. Although, there's some stripes on the printing, which I guess it is coming from the transfer belt.
          • Ricky Flynn
            Ricky Flynn
            • Mar 2024
            • 2
            Originally posted by valonqar
            Thank you ntbann and Larhal ! It seems to resolve one of the problems, it is stopping showing the message "adding toner" all the time and it's printing all the colors. Although, there's some stripes on the printing, which I guess it is coming from the transfer belt drift boss.
            Well the stripe problem on the photo print could be the belt, you should have someone check this.
            • valonqar
              • May 2025
              • 8
              I did, I changed the transfer unit, but now the message "adding toner" continues and keep asking to change toner k, but both (genuine and compatible) is completely full.
              • Larhal
                • 580
                Which toner did you have in when it gave the message? Compatible or OEM?
                Larhal
                • Scott
                  • 196
                  Never use generic toners in these machines. I am betting this is your problem as it will cause problems through out the machine if not immediately it will eventually
                  • ricohmaina
                    • Dec 2011
                    • 21
                    There is a tech pub for the 5526 for the premature out of toner issue.. Springs are added under the toner solenoid. I would expect this issue to have been addressed by Kyo. The tech pub is eight years old and I'm just now seeing the issue on machines installed last year.
                    302R794450 * PARTS PLATE SPRING SET SP
                    • valonqar
                      • May 2025
                      • 8
                      compatible, but I change for a OEM and the message to change toner K continues on the screen.
                      • Larhal
                        • 580
                        You need to stop using the compatible toner, I venture to say the transfer ports on the ITB belt are clogged up again. Remove the belt, vac out the ports and USE ORIGINAL Kyocera Toner, NOT COMPATABLE.
                        Larhal
                        • valonqar
                          • May 2025
                          • 8
                          Thank you for the advice. I vac out once again and the message stopped, now is printing. And yes, you right, I know that use not genuine toners decrease lifespan, but in my country is quite difficult to find oem for this printer, and they are overpriced.
                          • Larhal
                            • 580
                            Well just remember when happens again, and it will happen again, you know know what to do. Good Luck.
                            Larhal
