CS 2550 reset and network printing
  • CopyPasta415
    • Jun 2025
    • 1
    I am an accidental techie helping a small nonprofit in Washington, DC. We recently had a Copystar CS-2550 donated to us. It makes copies successfully, but I am trying to bring it on the network via Ethernet. So far, I've been able to get it to print if I connect directly to it via USB, but that's it.
    I think I need to reset it from its previous configuration. Any other tips? Is this copier too old for modern machines?
  • dalewb74
    • Feb 2018
    • 1163
    yes, you have a dinosaur.
    • Black Cloud
      • 170
      System Menu" > "System/Network" > "Network" > "Wired Network Settings" > "TCP/IP Settings" > "IPv4" > Then set DHCP to On. Then Power cycle the machine.
      You can set a static IP if you know about networking. This will get this museum piece on the network.
      Just for fun, check out the date of manufacture. It is stamped on the label on the back of the machine.
      Net+ PDI+ @Remote
