Kyocera P7035cdn paper back side stripes
  • markus
    • Dec 2021
    • 12
    Hello
    I print labels with the Kyocera P7035cdn.
    I use the front indent for this purpose.
    Only when I print there do I have red stripes on the back.
    Down from the cassette not.
    Does anyone know what that might be ?
    It's not that annoying because you throw away the sheet anyway.
    • 23010
    Re: Kyocera P7035cdn paper back side stripes
    I'm going to guess that the primary transfer belt is not performing second transfer completely, depositing primary transfer waste toner on the second transfer roller, then onto the backside of the paper.
    Does it help to select Thick1 or Thick2 media type for your labels? Labels are not Plain paper. =^..^=
    • markus
      • Dec 2021
      • 12
      I have set Labels as Paper.
      The same.
        • 23010
        Use Thick1 or Thick2, depending on the gsm of your labels. =^..^=
        • markus
          • Dec 2021
          • 12
          What does the setting Thick1 or Thick1 do ?
          The manufacturer does not specify paper thickness.
          It is AVERY Zweckform 3659.
          Universal-Etiketten | 3659 | Avery Zweckform
          • JR2ALTA
            • Feb 2010
            • 2033
            Slows the machine down. Increases heat and transfer bias.
              • 23010
              It's not paper thickness, it's paper weight (Grams per Square Meter). It's easy to calculate:
              Weigh 1 sheet of labels on a precision gram scale, divide that number by the percentage of 1meter area the page represents. Them you'll have gsm.
              Changing the media type changes a lot of things. It slows down the machine to increase fusing time. It increases the fuser temperature to correctly fuse toner to heavier paper. It increases transfer current so that more of the toner transfers from the belt to the label. =^..^=
              • L0rdC
                • Feb 2021
                • 82
                When in doubt, thickness 2
