Hi, Going to replace the black drum. Is there anything that needs to be reset, etc. Looking in service manual not sure if U119 resets all the drums even though replacing only black?
Last time I did one of those the DK had the steps to carry out in the box. Looks like you need to perform the following after replacement. Note, this is for the entire MK which contains DK and DV but I usually just step through for a single DK replace.
Do you go through a load of those drums on this model by any chance? Ive started cleaning out the drum blade assembly on these as the cleaning unit gets clogged. Can usually get some decent mileage after a clean before replacing.
