taskalafa 3501 question
  • Gab
    • Aug 2015
    • 671
    Customer asked to show him how to make 2 sided copy from book with one scanning
    We get in copy, duplex, more, book>>2-sided but print light is of and message "can not use this original sizeasa book original"
    what i have to do?
    • 30159
    Re: taskalafa 3501 question
    Check the original size
    The answer is in the error message
      • 23006
      As bsm says, this function is designed for 210mm x 297mm two up pages, or 297mm x 420mm for the two page layout (A3). I'll bet that your original is not that dimension.
      So lets say that your book is 150mm x 230mm, or 230mm x 300mm for the two page layout. Do you have any 150mm x 230mm paper loaded in the machine (set to Custom Size)? I think not. And even if you did, the machine is incapable of identifying that original size.
      A way around this is to align the book binding at 210mm left to right. Then cut some cardstock to fill in the gaps between your custom size and A4. Tape them down to the glass. Now you have a rectangular window on the glass to center your book, that will identify as two A4 size originals, and correctly choose A4 from the paper tray.
      The book to two-sided function is not as flexible as you seem to think. =^..^=
      • tsbservice
        Field tech
        • 8007
        Good old-fashioned trick that always work
