M6035 0511 Jams
  • fishleg
    • Mar 2009
    • 426
    M6035 0511 Jams
    Bit of a hard one to track down but I have a trouble machine that either keeps double feeding from tray 1. Brand new tyres checked the springs even tried different springs but it just ends up being called back in a few days later. Last time I went it suddenly set the tray to a5 even though the cassette was set to a4 on the dial. I flicked the little switches next to the tray a few times and it was back to a4.
    Seem to be seeing these double feeding a heck of a lot lately. Any one else had trouble like that?
    • 23009
    Re: M6035 0511 Jams
    We've had those size switches go bad. =^..^=
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1887
      Re: M6035 0511 Jams
      I believe on this model, if you read the manual, you have to replace the sep roller with the cassette installed. There's a lever that won't be in the correct position if you don't, and the sep roller doesn't mate up with the feed roller.
      I'm speaking from experience.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • fishleg
        • Mar 2009
        • 426
        Re: M6035 0511 Jams
        Know any hacks to over ride those sensors? Such a bad idea why can't it be set in the menu 😔.
        • fishleg
          • Mar 2009
          • 426
          Re: M6035 0511 Jams
          I've had that as well but it's not that on this one. I've just read a bulletin about putting some shims on the front of the tray so I might try that next. Supposed to help sep tyre release better when the tray is shut I might just take it off completely so it's always on.
            • 23009
            Re: M6035 0511 Jams
            If you're hands are steady, it's possible to disassemble the switch, and put a little more bend into the copper contacts. Keep in mind that the parts are very small, and it's very easy to break the plastic snaps that keep the switch latched shut. I have been successful most of the time.
            To get that switch assembly out, there's a hidden screw that is behind the fan on the other side of the frame. =^..^=
            • fishleg
              • Mar 2009
              • 426
              Re: M6035 0511 Jams
              Just a quick update I replaced the cassette and switch at the same time. So far so good the new cassette has a raised square where the sep pressure roller lever sits. I guess that will help put more pressure on but the switch definitely sorted mine.
