3050ci with light distorted copies.
  • Necrocannibal
    • May 2008
    • 212
    Had a tech go out and work on this machine today and the copies are light and slightly distorted. Prints look totally normal and scans look totally normal, it only does it when you copy and does it both in the feeder and on the glass. Here is an example with a status page beside it for comparison.
    Sent from my SM-N986U using Tapatalk
  • Drivee
    • Nov 2020
    • 322
    Re: 3050ci with light distorted copies.
    ECO mode is ON?
      • 16406
      It's difficult to tell a lot from looking at the status page. Can you print out some color test charts?
        • 900
        I agree ECO mode is on in printer settings .
        • rapo_tech
          • Feb 2019
          • 114
          He mentioned that internal prints are fine...
          As others said, you should check if ECO print is on under copy functions.
          • Necrocannibal
            • May 2008
            • 212
            ECO print is not on, it only does this if you copy, anything printed or from the machine internally is ok. I was talking with the tech, who is relatively new to this, and he said it's a pretty dirty place so he is going back to clean the optics Monday and see if it helps. I thought he did it but he didn't.
            • tsbservice
              Field tech
              • 8020
              Must be very dirty cuz on digital machine a have very rarely light copies. I would get back him to copier basics process.asap
              • Necrocannibal
                • May 2008
                • 212
                Like I said he is pretty new and it is so rare optics get dirty enough anymore to cause a problem. Not saying that is the issue, just hoping it is.
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  Not to belabor this but, what we just want to make sure you know there's 2 different Eco Prints that you need to verify are disabled.
                  Definitely have the tech clean the optics and run all calibrations available.
                  • Necrocannibal
                    • May 2008
                    • 212
                    Yes I know, like stated above internal prints look completely fine. If you'll look closely it's also distorting the print ever so slightly which is lesfing me to believe the optics are dirty.
                    • JR2ALTA
                      • Feb 2010
                      • 2033
                      But wouldn't internal prints look fine if Copy Functions Eco Print in ON? That's what we're saying. May not be correct but it's taking a while to get on the same page.
                      • Necrocannibal
                        • May 2008
                        • 212
                        Ecoprint is not on, it's been checked already, at the machine and at in the print driver. Ecoprint is the first thing he checked, plus the print is slightly distorted only while copying.
                          • 16406
                          How about making a copy of a color test chart and lets see if that holds any clues?
                          • Necrocannibal
                            • May 2008
                            • 212
                            He's going back Monday to clean the optics and go from there.
                            • JR2ALTA
                              • Feb 2010
                              • 2033
                              Did he find a solution?
