Taskalfa 305
  • copicatt
    • Nov 2008
    • 366
    Taskalfa 305
    • 23006
    Re: Taskalfa 305
    Loire is a dual component machine. So you'll need to add a bag of D4530 developer to the new empty developing unit. Run the developer stir. Then reset the developer counter.
    It sounds like you've familiar with Kyocera mono-component developing, which is different. =^..^=
    • copicatt
      • Nov 2008
      • 366
      • nathicana
        • Aug 2008
        • 332
        Re: Taskalfa 305
        Here's the way I would do it:
        Enter service setting menu
        Navigate to Developer unit
        Press start
        Restart machine then installation will be performed
          • 23006
          Re: Taskalfa 305
          Oops! My mistake. I mis-read Toshiba 305.
          You've got a Matsuri KM-305. Yes, this model is mono-component, and does need to fill the developing unit from the toner cartridge. It's in the service mode, like attached to the other thread.
          Sorry. I've seen to many different model 305's I guess. =^..^=
          • nathicana
            • Aug 2008
            • 332
            Re: Taskalfa 305
            Isn't this thread regarding the Kyocera 305?
            Looks like it is being interpreted as a Toshiba
              • 23006
              Re: Taskalfa 305
              My mistake. I immediately thought of the e Studio 305 (Loire).
              • copicatt
                • Nov 2008
                • 366
                Re: Taskalfa 305
                Press start
                • darry1322
                  • Oct 2010
                  • 817
                  Re: Taskalfa 305
                  Originally posted by copicatt
                  No problem! I was looking in the manual under the service mode settings. 10871087. Didn’t see where to add toner to it. Looks like that setting is elsewhere. Thank you
                  Go into System Menu, navigate all the way down to Maintenance, Service Setting, you should find the New Developer setting in there.
                  • justanotherhack
                    • Apr 2015
                    • 74
                    Re: Taskalfa 305
                    It is critical for Kyocera units to unplug the power cord before replacing units. It should automatically recognize a new developer unit and fill the developer with the mono-component toner when you power it up.
                    • sparkycivic
                      • Apr 2017
                      • 348
                      Re: Taskalfa 305
                      taskalfa 305 does not do this
                      • dalewb74
                        • Feb 2018
                        • 1150
                        Re: Taskalfa 305
                        if you purchase the developer unit from kyocera it will have the instructions in the box for the install process. including what simulations to run after you install the unit. very simple process on this model.
                        • Tom
                          • 344
                          Re: Taskalfa 305
                          Darry1322 winner winner chicken dinner. Sometimes I read these threads and have to remind myself this is an international site and people have wildly different experiences with machines. The taskalfa 305 was a faster version of the 255, both which were upgraded to the more commonly known 6525/6530, but essentially the same machine with the same toners and the same maintenance kits. Unlike most Kyocera's, these white box models did not use service sim 163 to add toner, but rather a setting accessed through the system menu located on the op panel. No need to enter 10871087 on these models, just press system menu, go to maintenance and select developer and it will add the toner to set up the new developer unit.
                          • darry1322
                            • Oct 2010
                            • 817
                            Re: Taskalfa 305
                            FYI : trouble reset is also in this menu but doesn't show until there is something to reset. (finisher fault)
