fs-3920 problem.. help please!
  • alpertevfik
    • Sep 2006
    • 38
    Hello; This vertical line should be straight problem... Has anyone come across this problem? ( laser unit, main board, engine board, power board, I tried changing.)WhatsApp Image 2022-04-08 at 16.42.49.jpg
  • JR2ALTA
    • Feb 2010
    • 2030
    Re: fs-3920 problem.. help please!
    i cant zoom in on that picture, but that may be on my end.
    From what I see i would think laser as well. Did you try to the ribbon cable ?
    • alpertevfik
      • Sep 2006
      • 38
      I tried the laser unit. The device does not have a ribbon cable.
        • 22999
        The only time I've ever seen wavy areas in the feed direction like this it's always been the laser. Was this a new laser, or a used part of unknown provenance? =^..^=
        • alpertevfik
          • Sep 2006
          • 38
          laser unit of the printer in a healthy working condition.
            Have a look at SB-2J0-0026-B297
            Zigzags might appear in the sub-scanning direction (vertical direction) as shown in the sample image below due to
            the contact failure between the heat roller bearing and the ground plate of the fuser unit. Therefore, the following
            changes were made in order to improve the contact.
            Content of Changes
            Ground plate (PLATE EARTH FUSER)
            - Change of the material (Hardened): SUS 304CSP1/2H SUS 304CSPH
            Change of the shape.
              SB-2J0-0026-B297.pdf
                • 22999
                Originally posted by skynet
                [ATTACH]52971[/ATTACH]
                So there's got to be arcing of some sort making the mirror motor unhappy. That's interesting! =^..^=
                • alpertevfik
                  • Sep 2006
                  • 38
                  I just saw your message, after replacing the fuser unit, the copy was fixed. I think it's causing a leak that will affect the laser engine. Thanks
                  • dalewb74
                    • Feb 2018
                    • 1132
                    i understand you wanting to repair this printer. but due to the age of it i would recommend looking at a replacement. you might just end up going in circles with the issue. and end up spending more in the long run. just a suggestion.
