reset on Ecosys P5021cdn
  • JanV
    • Apr 2022
    • 2
    Good day, how can I set the Ecosys P5021cdn to factory settings on the device itself. The way via the browser definitely does not work, it says there is no network cable connected, for whatever reason. So I need the way, via the device itself, which is just nowhere. Maybe someone knows advice
  • copier tech
    • 8205
    Re: reset on Ecosys P5021cdn
    Try updating the firmware then turn on DHCP let it pull an IP address & try logging in again.
    Chrome seems to be the most reliable browser.
    โ€‹
      • 23010
      I think I would start with checking the network cable, and making sure the correct IP is programmed on the machine. =^..^=
        • 30508
        What is the ipaddress of the printer
        What is the ipaddress of the PC?
        Both need to on same network
        manually set the PC to match the printer
        • JanV
          • Apr 2022
          • 2
          The network socket does not work and the cable is not defective, so it only needs to be reset on the device
