Copystar CS-255C need a part please
  • copykat93
    • Oct 2021
    • 281
    Hi Guys... I know its old, I know some stuff isn't available, but I have a customer who uses this machine strictly for labels & the T/S belt assy is clicking, I removed & swept out as much as I can & it stopped clicking, but thought I would see if anyone had one on the shelf they want to sell.... The best price I found was a bit over $200 plus shipping ..any help appreciated?
    One thing I wasn't sure of, will the TR896A from FS-c8525 work? The drums & dev units interchange, wasn't sure about the T/S belt
    • 23009
    Re: Copystar CS-255C need a part please
    Before ordering stuff, you should check to see if the primary transfer waste spout is clogged, or gears spun on the shaft. It's very common. =^..^=
    https://www.copytechnet.com/forums/k...tml#post958707
    • copykat93
      • Oct 2021
      • 281
      Yep... I totally agree... I swept out the auger as much as I could, everything on the belt moves freely including the waste auger when spinning the belt around & it is dumping into the waste container. This is the original transfer belt & the machine has 300K on it. Belt is worn pretty badly & needs replaced before it snaps. or starts having quality issues. I know about the issues with the primary auger plugging up & even where the shaft froze & gears spin freely... Thanks
        • 23009
        I suspect that you won't be able to swap the TR-895A 302K093071 (primary transfer belt unit KM-205C, KM-255C) as an exact substitute with TR-896A 302MY93061 (FS-C8020MFP, FS-C8025MFP, FS-C8520MFP, FS-C8525MFP), or TR-8315A 302MV93071 (primary transfer belt unit KM-2550ci, KM-2551ci). They are all Hanabi's.
        BUT, if you were desperate enough, perhaps you could transfer the consumable parts: belt, cleaning unit, gears etc, to the old transfer frame.
        I saw a lot of parts listings on the internet. I would think you could find a new TR-895A. =^..^=
        • copykat93
          • Oct 2021
          • 281
          I found one, Thanks guys!!
          • Ropariva
            • 680
