TA3554ci shrinking prints
  • mtcchuck
    • Oct 2016
    • 50
    Good Afternoon
    We just installed a 3554ci in a MAC environment. We used the driver that was on KDACentral. Unfortunately i dont remember what driver name/number was. Customer called today and said it is shrinking everything printed by 5 mil each direction. It is happening on all computers and all prints. When printing a PDF we found a option in paper handling that allowed us to print "actual image". That corrected that but it has to be changed each time. We couldnt find that same option when printing from Pages. We tried adjusting the document size, and all options such as; scale to fit and scale percentage. Customer has a TA4500i sitting beside the 3554ci that prints perfectly from all apps. My guess is a driver issue but that was the only driver that came up on KDACentral downloads for this environment.
    Any Mac guys or gals able to help me on this?
    Thanks in advance.
    Chuck
  • davidmtupper
    • Jul 2021
    • 326
    Re: TA3554ci shrinking prints
    Make the settings in Adobe reader then create a Preset at the top of the print window. Use that preset in other programs to see if that solves the issue, may or may not work but it is sometimes the only way to get settings to move between apps in a Mac environment.
    • mtcchuck
      • Oct 2016
      • 50
      Thanks! I will give that a try!
      chuck
      • Tonerkiller
        • Oct 2012
        • 669
        I have seen this. Change the PDL.
        • tec966
          • Mar 2009
          • 42
          Hi,
          For shrink or enlargement issue try U053 setting
          • TheBigB
            • Jul 2018
            • 8
            The 3554ci is AirPrint capable. Is there any reason not to use the driverless printing capability of AirPrint that is standard on every recent MacOS?
            Originally posted by mtcchuck
            Good Afternoon
            Thanks in advance.
            Chuck
            • PrintWhisperer
              • Feb 2018
              • 473
              Airprint is not driverless, and is designed for mobile devices. It uses embedded (Apple) drivers with limited functionality. The technology is more about discovery, connectivity, and driver support in a limited and restricted Linux based OS (all MAC products).
              For an Apple PC device, there is more support for installing manufacturer's drivers and using traditional network protocols which are not available in mobile devices, hence it is not the best fit there.
              "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
