Taskafla 2335
  • brantekcc
    • Jan 2022
    • 45
    [Misc] Taskafla 2335
    good afternoon all
    i hope someone can assist me please
    i need to find the home position for the lift cam on the DP7100 for Kyocera 2553 please
  • brantekcc
    • Jan 2022
    • 45
    Re: Taskafla 2553
    sorry typo its a 2553
    • Santander
      • May 2009
      • 768
      Re: Taskafla 2335
      Most likely you have a broken pivot point on the backside of the original lift plate. The feeder will cycle through trying to feed an original and error out with misfeed.
      • ntbann
        • Jan 2012
        • 622
        Re: Taskafla 2335
        That motor is controlled by sensors.
        • brantekcc
          • Jan 2022
          • 45
          Re: Taskafla 2335
          Hi All
          i think i have found the issue but not sure how to rectify ,i think the cam that moves the original lift plate is not in home position , i have attached a pic to show
          the cam , can any one maybe assist on how to get it back to home position please , the highlighted numbers is the cam i am referring to
          thank you in advance
          • ntbann
            • Jan 2012
            • 622
            Re: Taskafla 2335
            Like Santander said. Did you check the pin on the back side of the lift plate? That cam is controlled by sensors not by timing.
            • sparkycivic
              • Apr 2017
              • 348
              Re: Taskafla 2335
              This cam/motor can be rotated by hand, but all problems I've encountered with this plate are caused by the older design hinge pin that breaks under the excessive spring pressure. Newer plate has steel hinge pin.
                • 22927
                Re: Taskafla 2335
                I'll second that. There's a great deal of spring tension on that pin. I was able to repair one by inserting a steel pin and securing it with epoxy. =^..^=
                • 20gaugeO/U
                  • 553
                  Re: Taskafla 2335
                  Parts Lift Guide Assy SP
                  p/n: 303R794110
                  Replaced the plastic pin with a steel one. $5 part and a 15 minute fix.
