There is a bulletin for VoIP adjustments. Its old but it helps sometimes.
5053ci fax 12 not receiving fax
Did you ever find the fix for this? I'm having the exact same problem with a taskalfa 6525. Been there for years working fine, all of a sudden not receiving faxes. Customer didn't realize for a week cause faxes were sending out normally. Customer called phone company and they did a test and said everything looked good. Customers gets a good solid dial tone when they press "hook" on the screen, no static. They're in the next town over, so trying to get an idea before i go, I'll be bringing an extra fax board to swap out and a portable phone to hook up so I can call from my cell phone and see if it picks up. From what I've seen in various threads though, it could be a setting but I don't see what could have changed all by itself.Evil will always triumph because good is dumb.Comment
The basic diagnostics are always the came. Connect a POTS handset to the line. Call your cellphone from the POTS. Does it ring? Can you hear static? Your phone will display a phone number (occasionally the correct phone number if the line is dedicated to faxing). Call the POTS from your cellphone. Does it ring? Is it a distinctive ring? Can you hear static?
9 times out of 10 one or more of these functions is not working, and it has nothing to do with the MFP (remember the MFP is not even connected, it is a POTS handset). You cannot do this from the office. And if you ask an enduser to do this, there is a 50/50 chance that you will get an accurate answer. Just go out there. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=👍 2Comment
Have you tried a different Fax card? 2 screws to check it. That would eliminate the fax card being the issue.Comment
