light prints
  • brancas
    • Jul 2009
    • 78
    light prints
    hey guys. I have a TA 3051ci giving light prints as seen on the attached doc. The tech assigned to the customer serviced machine ran drum and developer refresh laser scan cleaning calibration and auto grey adjust. He examined all drum and dv units and Laser Scan Unit. All was well. The next step would be replacing laser unit and/or hi voltage unit. Any other suggestions?
  • Massimo Italy
    • Feb 2021
    • 45
    Re: light prints
    I would check the transfer belt, maybe if you have a try to replace it and see if the defect goes away
    • copykat93
      • Oct 2021
      • 272
      Re: light prints
      Not very familiar with the model, but that looks like a transfer issue, T/S roller, T/S belt..... what direction is paper running?
      • brancas
        • Jul 2009
        • 78
        Re: light prints
        Transfer belt was replaced
        • Massimo Italy
          • Feb 2021
          • 45
          Re: light prints
          Sorry, I realized that the translator has not done his duty, I meant if you can try to replace the entire transfer belt unit, perhaps with a unit that is working on another machine.
          • darry1322
            • Oct 2010
            • 817
            Re: light prints
            Running a U089 Sample Set might show more info about what's going on.
              • 22999
              Re: light prints
              I'd suggest that based on the image in the first post that you've got dirty polygon mirror surfaces, or other dirt on the optics inside the laser.
              I've cleaned plenty of these lasers. Just take care not to remove any mirrors. Like the scanner, the laser uses front surface mirrors. If the mirror is flipped over, you'll get both a reflective and a refractive image (it will look blurry). =^..^=
              • pascalb.
                • Aug 2016
                • 47
                Re: light prints
                Hello,
                as well as blackcat i had dusty lasers on this machine.
                Customer smoking next to the machine or very dusty environment.
                Good luck
                Do not lament,
                do not mock,
                do not hate,
                but understand.
                • Geo
                  • 662
                  Re: light prints
                  A couple of thoughts...Were ALL the shipping spaces removed from the transfer belt..Does a DV refresh have any effect ? IS OEM toner being used..?
                  • brancas
                    • Jul 2009
                    • 78
                    Re: light prints
                    The transfer belt was used taken from a working machine. Dv refesh did not work. Toner is OEM. The tech did remove the laser unit and cleaned all mirrors. Will give him another laser unit to install.
                    • tmaged
                      Owner/Service Manager
                      • Oct 2008
                      • 1870
                      Re: light prints
                      The mirrors on the polygon motor get dust in the trail end of each mirror. Remove the laser, flip it over and remove the 3 screws that hold each polygon motor in. That's the easiest way to clean them.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      Become a fan on Facebook
                      • Tom
                        • 344
                        Re: light prints
                        Weird how different environments cause these problems. Sounds like many of you live in dry dusty areas to have these problems. Here in Louisiana it's the humidity that causes the same symptom. We don't have much of a dust issue, but let that A/C not work for awhile when it's 90% plus humidity in the summer and we get light copies too on pretty much every machine. I can't place a kyocera in a warehouse or anywhere not climate controlled.
                        • JR2ALTA
                          • Feb 2010
                          • 2031
                          Re: light prints
                          As blackcat and tmaged said, this is 100% dirty polygon mirrors. NOT laser glass, which your tech may have cleaned. He needs to dig further. Don't waste a good LSU by replacing it.
                          • Geo
                            • 662
                            Re: light prints
                            Another thought... Other than the laser assy , did you check the transfer roller press springs and the side door latches.
                            • brancas
                              • Jul 2009
                              • 78
                              Re: light prints
                              Just an update. Gave the tech a used laser unit from a working machine and that solved the problem. Thanks for all the helpful advice!!
