Ecosys P2040dn, Reset Maintenance Kit
  • Hansoon
    • Sep 2007
    • 3385
    Customer got himself a maintenance kit for his Ecosys P2040dn, machine is over 100k and is asking in the display for the kit. Since I'm mainly a KonicaMinolta guy but a Kyo noob I do not have any information how to reset this indication. Any help please?
    Hans
  • KYO_OEM
    • Aug 2011
    • 719
    Re: Ecosys P2040dn, Reset Maintenance Kit
    When I am right, you'll find reset function after you entered system menu/ adjustment_maintenance/ service/ maintenance
    It will be visible only in case of >100k
    • progoffice
      • Nov 2008
      • 335
      It's too bad this can't be reset via KFS. It creates an unnecessary service call that could be avoided if you could reset it onsite when you're replacing the fuser unit every 30K when J4211 occurs. Usually a full PM has been performed before 100K, but there's no way to reset the counter until it reaches that point.
        • 23008
        Here are the service manual sections that you need:
        So it won't load the disassembly portion (too large).
