ecosys 6230cidn /6630cidn
  • brantekcc
    • Jan 2022
    • 45
    Good day <br><br>I have 3x ecosys 6230cidn /6630cidn machine all making a noise relating to the transfer belt , i have taken one of the belts and cleaned out the cleaning section and also vaccuumed out the shoots that feed the toner into the dev tanks , it works for about 5-8 pages and the nosie returns <br><br>has any one had this issue before and how was it reolved please
    • 23010
    Re: ecosys 6230cidn /6630cidn
    I once had a Gemini (ECOSYS M2126cidn) that was due for it's PM kit.
    When I fired it up after installing all the parts, I heard a drive belt jumping sound, which turned out to be the timing belt that turns the primary transfer belt cleaning unit. After some investigation I determined that the primary transfer cleaning unit on the new transfer belt was quite difficult to turn. It was getting late in the day ... rather than fiddle with the new cleaning unit trying to loosen it up, I recovered the cleaning unit from the old transfer belt, and installed it successfully on the new belt unit. The drive belt did not jump, and I did not hear from that customer again.
    That's where I would look. =^..^=
