Re: kyocera 5053ci loud noise, buzzing or is it gear grinding.
I have pulled toner rocks from the waste transfer unit the size of marbles. Also chunks stuck in the drop tube to the WTB. It can be done as I used my toner vac to suck them out and thoroughly cleared the transfer unit.
On the transfer belt take care if the discharge is plugged up with hardened toner. When that happens it usually strips the gear that drives the transfer screw. You can check that after it is all cleaned out by putting the fuser with the discharge port up and opened by rolling the cleaning roller to see if the screw is turning. If not it has stripped the concentric on the inside of the gear bore. I have pulled these and super glued to the shaft for a quick repair. If you don't repair or replace the gear it will load up the transfer belt cleaner and give CQ issues.
