Kyocera 5501i - print quality problem.
  • AlexRust
    • Apr 2014
    • 41
    Hi guys,
    I am trying to fix Kyocera 5501i - see attached sample. Can somebody please share from their experience which roller causing this "dots" at the top of the page on attached sample. I cleaned (to my knowledge) every roller in the paper path but pesky "dots" still there. Thanks in advance for your help.
  • dantab1980
    DanTab
    • May 2015
    • 16
    Re: Kyocera 5501i - print quality problem.
    The problem is your Drum charge roller. Replace it or the entire drum unit.
      • 23009
      Yes, primary charge roller. Repeating at 38mm intervals?
      Which sample is that? =^..^=
      • AlexRust
        • Apr 2014
        • 41
        Thank you. Will replace it and report back.
        • AlexRust
          • Apr 2014
          • 41
          Thank you guys, replacing charge roller did fix it.
            • 23009
            Congratulations on your success. Thanks for posting back. =^..^=
