taskalfa 5500
  • Gab
    • Aug 2015
    • 671
    taskalfa 5500
    Image is light about 4cm at one side in the direction of paper move. Any idea?
  • Samanator
    • Sep 2017
    • 578
    Re: taskalfa 5500
    A sample would be most helpful
      • 16383
      Re: taskalfa 5500
      Need more info. Do you have the same problem when printing and copying?
      Also, what have you done to try to correct the problem?
      • Gab
        • Aug 2015
        • 671
        Re: taskalfa 5500
        I am afraid i can;t give a sample because this a problem of a colegue from an other city. He Performed drum de humidity, developer initialazation and calibration. cleaned separation roller.
        • tonerleak
          • Mar 2012
          • 67
          Re: taskalfa 5500
          Check the transfer belt, they sometimes shift and cause blank/light areas, also check the charge roller, they are cleanable ( damp lint-free cloth) or if it's in bad shape change it if you can. Also check the developer unit , the dev roller gets worn and causes quality issues. Hope this helps!
          • ntbann
            • Jan 2012
            • 628
            Re: taskalfa 5500
            Could be dirty polygon mirror tips.
