Replacing 302K302170 (FRAME REAR UPPER) on 3011i
  • inreverie
    • May 2022
    • 5
    [Misc] Replacing 302K302170 (FRAME REAR UPPER) on 3011i
    Does anyone have experience replacing this particular part? My partner and I have been working on it all day, to no avail. I have removed the bridge and upper drive unit. I am beginning to think this is not a part designed to be replaced in the field. If it is, can anyone give me a short run down on how deeply or what else I must remove in order to replace it correctly? I have successfully gotten the fuser input snapped in place with the cables behind it, but cannot get it closer than a half inch or so flush with where it belongs. Any comments or guidance is very appreciated.
    Thanks.
    • 23006
    Re: Replacing 302K302170 (FRAME REAR UPPER) on 3011i
    This? Number 6:
    By all appearances you'd have to fully remove the scanner to access the inside of the rear frame. I can't say that I've ever tried to get to that part.
    If you don't mind me asking: why do you need to change that part? =^..^=
    • inreverie
      • May 2022
      • 5
      This? Number 6:
      [ATTACH=CONFIG]54736[/ATTACH]
      That's the one!
      Someone seems to have snapped an integral part of plastic from the one we removed (most likely by forcing in the fuser incorrectly), and as a result it wasn't properly supporting the fuser. I've never removed a scanner before. Would you suggest that something I attempt without proper guidance from the SM? I've replaced drive units and all diff PWBs but this sounds pretty massive, and of course it's something as simple as a plastic cover.
        • 23006
        I've had a number of scanners off. As long as you leave the scanner internal parts alone, there aren't any critical adjustments.
        In broad strokes;
        Remove the DF
        Remove all the covers
        Disconnect harnesses to the scanner
        Unbolt the scanner from the main frame
        It's probably not something I'd do in a customers office if it were my first time.
        • Fabio-1
          • Mar 2022
          • 6
          Changed it on a Kyocera 4012i, I have to remove fuser, bridge (if the is), the cover tray, the cover front, the cover exit rear, in that way you could frontally remove the guide fusers screw and then the frame rear upper. I don't know if in the 3011i you could follow this procedure, but I think they were built in the same way.
