Magenta lines on copies any ideas
  • outdoorkatie123
    • Feb 2017
    • 50
    Hi anyone ever have this fault everything colour has magenta lines covering the copy but there is no magenta in the copies
    if i run a calibration the magenta is missing
    if i do a one colour magenta the copy is blank apart from the magenta lines
    • 22979
    Re: Magenta lines on copies any ideas
    It would be nice to see a sample. Something like this:
    And it might help to know what model that you're referring to. =^..^=
    • outdoorkatie123
      • Feb 2017
      • 50
      SAMPLE COPIES-5.jpgSAMPLE COPIES-4.jpgSAMPLE COPIES-3.jpgSAMPLE COPIES-2.jpgSAMPLE COPIES-1.jpg
      Hi here are some of the sample copies i took whilst on site
      everything copied or printed in colour has magenta lines all over the page
      already replace magenta drum and dev unit primary transfer belt hv board and main power supply
        • 22979
        If your copier has a charge roller (or four), I would start with cleaning the magenta primary charge roller.
        I still don't know what model copier you have. =^..^=
        • copykat93
          • Oct 2021
          • 269
          I agree about the charge roller cleaning, clean water on a cotton cloth and clean the charge roller
          BUT...YEAH!!.... sure would be nice to know what model machine you need help with
          • outdoorkatie123
            • Feb 2017
            • 50
            Hi guys the copier is a UTAX 3206
            ive already replaced the complete drum unit which comes complete with charge roller also replaced magenta dev unit and primary transfer belt
            Although all colour copies have the magenta lines there is no magenta in the actual copies
            if you look at the sample calibration the magenta square is missing
            thanks
            • copykat93
              • Oct 2021
              • 269
              hmmmmmm.... what does that convert over to in a Kyocera?
              • outdoorkatie123
                • Feb 2017
                • 50
                TASKALFA 2552ci
                  • 22979
                  Is the little gray button staying pressed in on the developing unit?
                  Is the laser slit glass clean?
                  Less likely: perhaps the magenta primary transfer roller is not shifting correctly, maybe popped out of it's bushings?
                  Have you emergency stopped the machine to determine if you have a good latent image on the magenta drum? ... on the primary transfer belt? =^..^=
                  • PrintWhisperer
                    • Feb 2018
                    • 455
                    My guess is LSU magenta laser drive is fubar. Note existing deletion edge indicating good charge and no defect where laser does not write to.
                    This is why bias components had no effect. Loupe examination of defect should show some level of dot pattern.
                    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
                      Hmmmm....I'm torn between PrintWhisper and Blackcat's solution.
                      • outdoorkatie123
                        • Feb 2017
                        • 50
                        Already replaced primary transfer belt and the dev unit doesnt have the little grey button
                        • outdoorkatie123
                          • Feb 2017
                          • 50
                          Problem solved turned out to be faulty Engine pwb
                          • copykat93
                            • Oct 2021
                            • 269
                            That is weird... but so glad you found the issue & shared it with us. Have a great day!
                            • PrintWhisperer
                              • Feb 2018
                              • 455
                              Good job parsing LSU drive signals, you should also carefully check the waste toner bottle is turning without obstruction.
                              This is because the Engine PWB->Laser APU connection includes a 24v line to supply LSU cleaning motor.
                              This voltage is also used to drive the WT motor. If there was an overcurrent due to mechanical binding that could have zapped it.
