TA 3552ci grinding noies w/C7301
  • Samanator
    • Sep 2017
    • 579
    I have this 3552ci that I was called out to that was making a grinding noise. The customer had turned it off. When I switched on, it made a grinding noise for a bit then made a C7301 and of course stopped. O month before I had replaced the transfer belt unit and the PARTS BOX WASTE H ASSY SP because of a different grinding noise caused by toner rocks on the waste box and a non repairable stopped up transfer belt nozzle. When I pulled the drive unit (something I have sadly become very familiar with doing), the gear on the waste box moved very smoothly with no drag or hesitation at all . However looking back into the machine around where the black developer connects, I discovered all kinds of powder that I think is from a gear (see pictures). When I inspected the black developer unit, I discovered more of the same.
    This is the first time I have seen this before and heard the different grinding noise as well. Has anyone experienced this before?
    If you have, whats the fix, please?
    Thanks so much for any help.
    • 23008
    Re: TA 3552ci grinding noies w/C7301
    I'd suspect that the gears are wearing because the black developing unit is difficult turn. Back when we saw this issue on AlphardI's I tried disassembling a couple of developing units. Mostly all you end up with is a broken plastic housing. When it became clear that I wasn't going to have a usable developing unit, I abandoned that idea, and ordered a replacement. As far as I can tell the housings are all glued or welded, so it's just not coming apart into usable pieces.
    As a contributing factor I's check for generic toner. =^..^=
    • Samanator
      • Sep 2017
      • 579
      Thanks BC. Do you think I should replace those gears on the inside the machine? Looks like a bitch (like my ex) to get at.
      I will try another black developer unit and see if that straightens this out.
      This is a client that purchased the machine outright and did not take a service agreement. Not sure where they get their toner, but its not from us. And yes, the toner bottles in the machine are aftermarket.
        • 23008
        If it was an option, I'd like to temporarily swap in a used developing unit to see if it drives.
        If it does drive, I probably would not change those gears in the back. I would also tell my enduser that I suspect the aftermarket toner to be the cause, and if there was a re-occurrence I could not warranty the parts.
        If you can get a peek down inside the black developing unit, I suspect that you'll find that it's full to the brim with toner. You may also have backups in the toner add augers. Don't give an estimate that locks you in to a specific price or number of hours. It could be a major operation ... and if they continue to use the aftermarket toner, you may get another opportunity to do it again. =^..^=
        • Samanator
          • Sep 2017
          • 579
          Put a different black black developer unit in it and when the machine came on it still made a racket, ran for a while during warmup, then C7301.
          So it looks I gotta replace those gears; GEAR Z19L (302ND03440) and GEAR Z25R (302ND03450) found in parts under FIG. 6 Frame Base.
          Ugh!
            • 23008
            Ugg, is right. =^..^=
            • Samanator
              • Sep 2017
              • 579
              In one picture the worn gears that drive the black developer unit is quite apparent.
              In the other picture, one can see how clean one can make the machine when replacing gears of this type.
              Ugh!
                • 23008
                That is a naked rear frame.
                Nice & clean. Yeah those gears were toast. =^..^=
                • Samanator
                  • Sep 2017
                  • 579
                  Now I have discovered that there is no way to remove the gears from the shafts without concealable destruction (pic Part xx).
                  Nor is there a part number for the black assembly where they reside (pic Part X).
                  Ugh!! this just keeps getting better.
                  Have reached out to Kyocera parts with a nicely worded WTF??!!
                  Stand by friends as we see what happens.....
                    • 23008
                    If I'm viewing that correctly, those gears are on shafts riveted into the frame ... aka: not removable without drilling out the frame. =^..^=
                    • Samanator
                      • Sep 2017
                      • 579
                      Yup. That's the problem.
                      Kyocera, you got some 'splanin' to do...
                      • Samanator
                        • Sep 2017
                        • 579
                          • 23008
                          Kyocera uses these split-rings on a lot of things. It looks like they were new enough that they didn't break.
                          When we were having so many problems with the Alphard3 transfer belt units, I took apart 6 or 7 of these units in the hopes of figuring what the hell was causing the transfer issue. Other than learning how to take them apart quickly, I never did determine what was causing the early failures.
                          If you need any more of those split-rings I have a pile of them.
                          Congratulations on your success. =^..^=
                            • 16392
                            Good job. I enjoyed the read.
