CS 3552ci J4101
  • StratManDan
    • Nov 2018
    • 96
    CS 3552ci J4101
    Can anyone share any information you may have on this jam code? The jam will clear, however it occurs every time, first print. The lead edge is making it past the registration roller/sensor, but stops dead in it's tracks, and puts several Z folds in the paper. This is not a crash jam, as the lead edge isn't hitting anything.
    Any ideas?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    Re: CS 3552ci J4101
    The sensor over the transfer roller is called multiple names in the service manual, so it sends you on a chase. It's in the right door, center above the transfer roller.
    I just found this out a few weeks ago, but if you run U031, then system menu, start a copy then hit system menu again, you can watch the sensors change state.
    If they are changing, then you're looking at a clutch, but usually you'll get them to at least pass intermittently.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • StratManDan
      • Nov 2018
      • 96
      Re: CS 3552ci J4101
      I will check that out! Good to know! Thank you!
