Need the Firmware File For Kyocera 356ci printer
  • nexxus2009
    • Oct 2022
    • 10
    #16
    Re: Need the Firmware File For Kyocera 356ci printer
    Originally posted by PrintWhisperer
    Please note specific name of part for your machine:
    306ci may have optional 32GB or 128 GB SSD (not HDD) and runs HyPAS from SSD or SD card.
    356ci/406ci has standard 320GB HDD (not SSD):
    [ATTACH=CONFIG]55337[/ATTACH]
    Good morning every body
    PrintWhisperer : This is a global view of the motherboard ... according picture that u sent me there is NO HARD Drive ....
    I tried to look in other parts but nothing...
    the red cable in the top of picture is connected directely to the monitor motherborad
    I cannot find the HDD
    Any help please ... Thanks a lot
    • PrintWhisperer
      • Feb 2018
      • 473
      #17
      I tried to look in other parts but nothing... Any help please ... Thanks a lot
      Thank you for good pictures. You indeed have SSD and not HDD.
      My apologies for the USA centric reply as the HDD is standard only on 120v 356ci-406ci models.
      So you have EU-356ci with SSD and I can only refer to US-306ci instructions for it's location:
      NOTE: For '3' series A3 machines like the 6053ci series, the SSD is tricky to deal with. Existing SSD in machine has many partitions and if they are removed the SSD becomes unresponsive. These machines will not boot without an SSD, but they will boot without an HDD. So like always machines will generally boot with-out an HDD (especially when it's optional) but they use the SSD as the BOOT partition for the Linux operating system.
      Plus they are M2 SATA, this looks to be mounted on a interface card and might not even be removable and then you would need a PC connectd M2 SATA cradle hooked to USB to even see the partitions and format anything. (Yes, I've done it)
      May as well order a new one.
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
        • 16416
        #18
        [ATTACH=CONFIG]55363[/ATTACH]
        You're like the Wizzard.
        • nexxus2009
          • Oct 2022
          • 10
          #19
          exactly,the problem is that i cannot localize it to unmount the right part of the printer ...
          • PrintWhisperer
            • Feb 2018
            • 473
            #20
            So then yours is NOT mounted in the Interface Slot for options?
            • nexxus2009
              • Oct 2022
              • 10
              #21
              No these tow emplacements are Empty . A friend found this :
              and according to description, the part number 33 is called : Part SSD SP. I dont know if is it the main SSD or not
              • PrintWhisperer
                • Feb 2018
                • 473
                #22
                [ATTACH=CONFIG]55455[/ATTACH]
                Yes, that shows the SSD mounted to the MAIN PWB. It should be behind the little black fan assembly and it IS in a typical M2 slot:
