Black Band across page
  • LiamXCIII
    • Apr 2022
    • 29
    Hiya,
    Anybody seen this type of fault before on a Ecosys M3655idn? MFD version of a P3145dn
    Inch wide black bands down prints.
    Image attached
    • 23009
    Re: Black Band across page
    It look to me like your primary charge is cutting out. I would start by replacing the drum unit. It could also be the HVT. =^..^=
    • copiertec
      • Jan 2016
      • 2211
      My crystal ball is not working today. What is the page count? What is the maintenance kit page count? What have you done to resolve the issue so far?
      • Samanator
        • Sep 2017
        • 579
        Maybe he thought he was reaching out to the Copytechnet Psychic Hotline (13 minuets for $10).
        That's a one eight hundred number I do not have on me at this time.
        They ought to know you're dialing before you call.
        • LiamXCIII
          • Apr 2022
          • 29
          Hehe, have you tried turning your crystal ball off and on again :P lol!
          Meter of device is 165,000
          Same goes for Maintenance kit
          I had a spare printer of the same, so was able to rob some parts.
          Have already tried replacing the drum unit and the HVT, but to no avail
          Took out transfer roller, gave the contacts inside a clean.
          Can't see any obvious signs of damage, device was working perfectly fine and then all of a sudden these black bands appear.
            • 23009
            Perhaps the developer bias is shorting, causing the HVT to cut out. Try the developing unit. =^..^=
            • LiamXCIII
              • Apr 2022
              • 29
              Thanks Blackcat,
              Sorry I should have said Imaging unit as a whole, I took out the entire lump from one device to this, so that included the Dev unit, Drum unit and toner cartridge aha 0_o
              • toddanderson
                • Dec 2005
                • 236
                How wide is the band measure
                Originally posted by LiamXCIII
                Thanks Blackcat,
                • LiamXCIII
                  • Apr 2022
                  • 29
                  I'd say the band is a good inch wide
                  • Gab
                    • Aug 2015
                    • 671
                    Hiya,
                    Image attached
                    Under the 2 black lines is image ok? I see 2 other white lines with same width.
                    • LiamXCIII
                      • Apr 2022
                      • 29
                      Image appears normal between inch wide bands, the first band is solid black followed by an immediate two-tone band, starting white gradually getting darker.
                      • copiertec
                        • Jan 2016
                        • 2211
                        Have you checked wall voltage that the machine is plugged into? Looks like voltage/ground issues.
                        • LiamXCIII
                          • Apr 2022
                          • 29
                          I moved the device to a different location to work on it, tried a different kettle lead too, same problem occurs.
                          Will have another crack at it tomorrow now the device is in the workshop. Will try strip it down and clean any of the charging contacts I can see. Maybe I'll come across a staple or something...... :'D
                            • 23009
                            I'll be interested in what you discover. =^..^=
                            • Gab
                              • Aug 2015
                              • 671
                              High voltage
