Kyocera Ecosys P3155dn - blank space at the begining of each page
  • rankdown
    • Nov 2022
    • 5
    Hi all,
    I have a problem with top blank space on paper when printing on Kyocera Ecosys P3155dn. Its not only on first page but on every page.
    Its happening even if I just print test page on printer.
    Any suggestion is welcome!
    I will put link here for you to understand better: https://i.postimg.cc/50hwMTLk/IMG-20221116-141548.jpg
    Thanks!
  • copiertec
    • Jan 2016
    • 2199
    Re: Kyocera Ecosys P3155dn - blank space at the begining of each page
    Looks like registration is off? Have yo tried through the bypass to see if you have the same issue?
    • rankdown
      • Nov 2022
      • 5
      Yeah I tried through bypass and its still the same.
      Sorry for not writing it earlier.
      • CWP
        • Jun 2013
        • 168
        Check registration roller / clutch to make sure it is not sticking and driving continuously.
        • rankdown
          • Nov 2022
          • 5
          I checked registration roller/clutch and everything seems fine.
          Still thanks.
          Only thing that is strange is that something is very loud and there is crack sound every time it prints something.. need to check that..
          It have 1.300.000 prints but still not giving up on it! :P
          • copiertec
            • Jan 2016
            • 2199
            It have 1.300.000 prints but still not giving up on it! :P[/QUOTE]
            WOW! I had no idea they could run that long. I know Kyocera makes a decent printer, but 1.3 million...wow.
            • lees
              • Apr 2011
              • 95
              With that many prints on the machine, replace the registration actuator. I have not seen this cause the problem you are having, but it will cause intermittent jamming starting sometimes around 750,000 prints. It may not look worn until you remove it and put it beside a new one. I generally recommend replacing them about 750,000 prints just to prevent jamming issues that will get worse with time. Hope this helps.
                • 23003
                The registration clutch and bushings should be DESTROYED at 1.3M. At 1M the bushings oval out, the rollers lose contact and the gears disengage. Also the registration actuator can be cut completely off, not just grooved.
                If I remember correctly there are no part numbers listed for the bushings. I reached into my 5 gallon bucket of miscellaneous bushings to find (4) that fit. =^..^=
                • rankdown
                  • Nov 2022
                  • 5
                  Thank you lees I will definetly try your sugggestion! Nothing to lose here :P
                  Thank you blackcat4866 for the info I will try to find the culprit :P This printer is well maintained, last big maintenance was on 1M. But yeah anything could be wrong by now... Still want to fix it!
                  Worst part of this "error" is that there is no any info on web and I have never seen it so I tried on this forum!
                  Still thank you all!
                  • tsbservice
                    Field tech
                    • 8002
                    I think it's time to upgrade this one, the real problem is will you find another solid machine.
                    Nevertheless great job keeping this machine alive and kicking.
                    • rankdown
                      • Nov 2022
                      • 5
                      Yeah its true.. this one is rare gem.
                      Thank you for your kind words but I shouldnt take the credits for it because it was my boss who maintained it.
                      Now its my time to shine :P or this printer is just doomed because it came in my hands.. who knows.. we will see ._.
                      p.s. Why didnt I asked my boss what could be wrong? I dont want to bother him for now and I want to try to fix it by myself (Now its not "by myself" cuz I got some tips from you guys.. but he doesnt know that hehe).
